Destiny Raiding Normal And Hard Mode
OK guys for me this is crucial as i am trying to get on end game farming hard mode asap.
I will be running normal raid on a daily basis to help around who ever needs it. I just request you be 280 and above if we have a group that's 300 plus and you 270 no issue as long long as you can follow directions you are a go. No exceptions on that. times vary so first come first serve, i have ran the raid on a daily basis more than once or twice so not an issue for me.
Hard mode definitely NO EXCEPTIONS until we can progress farm it your light must 306 and above subclass that you will be using must be fully leveled or the bubbles filled for the crucial part that you need ("ie. if your using a lock radiance on hard mode is a must, titans bubble blessings is crucial to our survival in some fight so at minimum blessings must be unlocked, hunters well dont know much about hunters but you should get it by now that tether is a raid helper so enough said")
raid times for hard mode even if i have done it will be Saturdays at 1800 central time zone. if the raid was not finished it will continue with the same people not different, exception to that will be if the member told us hey i wont be able to finish the raid for what ever reason then we will either lfg or collect the next in line.
With that being said I raid with a group on hard mode if it runs on Saturday past the time we need to start i will message you guys to let ya know i will be running late. just let that be known they are my progressing team and long time friends.
back to the original post if you are down just go ahead and post what you are signing on for and we will get this going.
