Ive found the IMR to be perfect for search. As far as kill streaks. Run everything u can with support if you have the space. Overclock is also a great thing to have for snd.
I hate system hacks so will never not have hardwired on...lo.
I can't however seem to build a decent pistol class like blops2 no marathon perk which is key in my blops2 pistol class
I NEVER run pistols. I am horrible with them so id rather just have my combat knife and go in cloak (if i have it at the time)
For S&D I typically use Tactician. Having Overclock to get their Flanks right off the bat with Exo Mute Device so they can't hear you coming is underrated and gives you an extreme advantage.
I like the AK12 but I feel the mag size is too low if you're going to be using Overclock you're likely to engage in multiple enemies or have a much larger chance at it. I prefer using the ASM1 with Tactician but if you're deadset on the AK12 then I would suggest putting Extended Mags on it for the better feeds.
Stun Grenades in S&D work as well. Typically people camp in the same areas on S&D the ones that give them the most advantage. You can use the Stuns to take that advantage away but also not bother checking an area if you've tossed a stun in there and got no hit markers on it - This pretty much enables a faster clear if you're on a time crunch.
Typically lightweight / Stock is good/necessity if you're running the above setup. While UAV's can be dangerous to you, you will or should be moving around enough that it doesn't cause too much concern. However, you can chose to go with Perk 1 Greed and add in Low Profile if you feel it becomes to problematic and best fits your play style.
Toughness / Blast Suppressor are the better Perk 3 choices with Peripherals for a Perk 2 or Cold Blooded is also good.
heres some i have fond on a site..
Jumping into a Call of Duty: Advanced Warfare multiplayer match is easy. Choosing yourPick 13 is the hard part. There are a wealth of weapons, attachments and Exo Abilities in Activision’s latest first person shooter, and you’ll need to create different loadouts and make tweaks depending on the mode. Thankfully, the developers at Sledgehammer Games offered their own personal setups in Newsweek’s Advanced Warfare collector’s edition guide. That said, experiment with these loadouts from the talented men and women who designed the game, then let us know which one worked best for you.
Sean Marino (Weapons and Vehicle Artist)
Guy Beahm (Multiplayer Level Designer) 1
- Primary Weapon: MP11
- Attachments: Red Dot Sight, Rapid Fire, Quickdraw
- Secondary Weapon: Combat Knife
- Perks: Lightweight, Overcharged, Fast Hands, Blast Suppressor, Scavenger
- Exo Ability: Exo Stim
- Exo Launcher: None
- Wildcards: Primary Gunfighter, Perk 1 Greed, Perk 3 Greed
- Scorestreaks: None2
Mike Mejia (Producer)
- Primary Weapon: IMR Assault Rifle
- Attachments: Red Dot Sight, Stock, Quickdraw Grip, Advanced Rifling
- Secondary Weapon: HMR Submachine Gun
- Perks: Lightweight, Toughness, Scavenger
- Exo Ability: None
- Wildcards: Overkill, Primary Gunfighter
- Scorestreaks: Paladin, Aerial Assault Drone2
Michael Condrey (Sledgehammer Games Co-Founder)
- Primary Weapon: ASM1 Submachine Gun
- Attachments: Red Dot Sight, Quickdraw Grip, Laser Sight
- Secondary Weapon: None
- Perks: Lightweight, Fast Hands, Blast Suppressor
- Exo Ability: Exo Overclock
- Exo Launcher: Variable Grenade x2
- Scorestreaks: Orbital Care Package (Modules: Better Odds), XS1 Goliath
Travis Naas (Senior Sound Designer)
- Attachments: Red Dot Sight, Quickdraw Suppressor
- Exo Ability: Overclock
- Exo Launcher: Frag Grenades x2
- Scorestreaks: UAV (Orbital VSAT), Orbital Care Package2
Craig Louie (Multiplayer Designer)
- Primary Weapon: S-12 Shotgun
- Attachments: Laser Sight, Advanced Rifling
- Secondary Weapon: RW1 Pistol
- Perks: Lightweight, Gung-Ho, Toughness, Blast Suppressor
- Wildcards: Perk 3 Grenade
- Scorestreaks: UAV
Greg Reisdorf (Lead Multiplayer Designer)
- Attachments: Rapid Fire, Foregrip, Laser Sight
- Perks: Lightweight, Overcharged, Gung-Ho, Blast Suppressor
- Exo Ability: Exo Shield, Exo Overclock
- Wildcards: Primary Gunfighter, Perk 1 Greed, Tactician
Kelly Mermelstein (Lighting Artist)
- Primary Weapon: KF5 Spanner
- Attachments: Quickdraw Grip
- Secondary Weapon: XMG Bacon and Eggs
- Perks: Lightweight, Blind Eye, Toughness
- Exo Launcher: Tracking Drone
- Scorestreaks: Missile Strike, Aerial Assault Drone
Alejandro Gil (Multiplayer Art Director)
- Attachments: Rapid Fire, Quickdraw Grip
- Secondary Weapon: ASM1
- Perks: Lightweight, Fast Hands, Toughness
- Exo Launcher: Semtex x2
- Scorestreaks: UAV (Module - Enemy Direction)
Rosie Katz (Senior Level Designer)
- Primary Weapon: Multiple Detonation Launcher
- Secondary Weapon: Bulldog Shotgun
- Perks: Lightweight, Flak Jacket, Gung-Ho, Fast Hands, Scavenger
- Wildcards: Overkill, Perk 1 Greed, Perk 2 Greed
- Scorestreaks: UAV
Aaron Halon (Director of Product Development)
- Primary Weapon: AK12
- Attachments: Extended Mags, Foregrip, Quickdraw Grip
- Perks: Lightweight, Cold-Blooded, Toughness
- Exo Launcher: EMP Grenade
- Wildcards: None
- Scorestreaks: UAV, Orbital Care Package
Josh Katz (Senior Level Designer)
- Primary Weapon: MORS The Doctor (Elite)
- Attachments: Stock
- Secondary Weapon: RW1 Guardian
- Perks: Lightweight, Fast Hands, Hardline, Blast Suppressor
- Exo Ability: Cloak
- Wildcards: Perk 3 Greed
- Scorestreaks: Orbital Care Package, Remote Turret, Warbird
Colin O’Connor (Senior Multiplayer Animator)
- Primary Weapon: HBRa3
- Secondary Weapon: Atlas 45
- Perks: Lightweight, Cold-Blooded, Blast Suppressor, Scavenger
- Exo Launcher: Frag Grenade x2
- Scorestreaks: UAV
- Attachments: Extended Mags, Red Dot Sight, Suppressor
- Perks: Lightweight, Low Profile, Gung-Ho, Blast Suppressor
- Wildcards: Perk 1 Greed
- Scorestreaks: UAV
To me you wont find Pistols in AW like you had in Black Ops 2. They're all pretty much worthless. Even the 1 shot pistol is so hit or miss it's almost not worth using.
I know a lot of Snipers that actually run Overkill and slap on an SMG to get themselves out of sticky situations of course they use Fast Hands as their Perk 2 for this. May want to try that instead of going with a Pistol if you're sniping.
The only ak12 ive had any issue with is the r.i.p since it only holds 22. I use the finger trap and the stock ak all the time and it does the job. Thats a good idea for the exo abilities. I normally just have overclock but u have a point. U could do a lot more damage if they dont know you are there. Gonna have to run it later
The only reason I was trying to builds pistol class is to try for my pistol marksman... I usually run the ak12 ever since qu33n recommended it.
