Results 1 to 8 of 8
Thread: Sensitivity Setting?
Discuss all topics concerning the Black Ops series here
    iamsnakeplisken's Avatar
    Rep Points: 6750
    May 11th, 2025
    08:07 AM
    NJ
    Bravo Co Reserves Leader
    What is the impact of changing your sensitivity? What do you recommend as a setting and why?
    Bob Hauk: You going to kill me, Snake?
    Snake Plissken: Not now, I'm too tired.
    Snake Plissken: Maybe later.
    Experience: 1,572,842
    jDIAMOND's Avatar
    Rep Points: 3635
    May 11th, 2025
    07:07 AM
    Warren, Ohio
    Re: Sensitivity Setting?
    If u are a run and gunner then I recommend a high sensitivity. You can turn quicker. I have mine at 5 for camping and running...
    Sent from my PG86100 using Tapatalk 2
    Experience: 15,917,408
  3. The Following User Says Fucking Hell Yeah ! to jDIAMOND For This Fucking Post:
    Rick James's Avatar
    Rep Points: 9511
    May 11th, 2025
    08:07 AM
    new jersey
    Mine is 7. Mainly because of zombies but I'm a run and gunner in multiplayer
    Experience: 2,923,862
    May 11th, 2025
    07:07 AM
    Quote Originally Posted by iamsnakeplisken View Post
    Snake I have improved raising my sensitivety do to afreind of CAG MamaDukes thanks to her
    Sent from the trunk of Cheech's 57 Chevy using tap talk.
    Experience: 12,703,602
    II MORBID II
    May 11th, 2025
    12:07 PM
    Guest
    Sensitvity is all based on you play with what your comfortable playing with. I personally play on 6 I see allot of players playing at to high of a sensitvity and cant make the distance shots try raising it slowly 1 at a time. You will notice a slight change going one at a time dont go jumping to 7 if you play at 3 or 4. If you enjoy using a assault rifle play at a lower sensitvity makes those long shots a little easier. With me being a SnD player i like Sub's there for a higher sensitvity is better for turning on my victims.
    CAG Dogg Level: 1 [?]
    Experience: 0
    Next Level: 10
    CAG Death's Avatar
    Rep Points: 27835
    May 11th, 2025
    08:07 AM
    Jacksonville,Fl
    I run at 8
    cag death
    Experience: 5,001,975
    May 11th, 2025
    08:07 AM
    i dont touch mine. i leave it bone stock which is now 4. and i run and gun. i very very rarely will not get those quick adjusters but it doesnt happen enough to make me raise it. i find that i even less rarely miss at range. and thats how i get alot of my kills. recognize and attack. i only play on a 34 inch flatscreen but it is literally 1 mabye 1 1/2 feet from my face, eye level. i find it absolutely imperative for your tv to be eye level. i just play so much better that way. so it all works excellent for me.
    Experience: 49,900,857
    May 11th, 2025
    04:07 AM
    What works for 1 or 2 might not work for you.
    I don't run around much so I have mine set as low as 2 at times for those long shots. When I do decide to move around I raise it up around 7-8.
    Experience: 291,841,597
