Results 1 to 8 of 8
Thread: All COD Ghost Perks With Descriptions Get a Head Start On Your Class Ideas!!!!!!!
Any information regarding the 1st Platoon is here. All teams for our GB squads will be present here. All game modes will be represented within BOP2 MLG.
    NIGHTMARE's Avatar
    Rep Points: 14083
    May 25th, 2025
    08:45 PM
    Stony Brook, NY
    Hey guys found a list of all perks with descriptions get an idea of what classes your going to create. Lot of variety out here this game is going to be insane. ENJOY!
    Ghosts - Perks List
    ghosts perk icons 1Call of Duty: Ghosts multiplayer perks provide powerful, game-changing abilities and bonuses to your custom classes. Some of them allow you to sprint longer, change weapons faster, be undetectable by enemy Sat Coms, etc. There aren't stronger or weaker perks, but rather situational ones.
    Their effectiveness depends on the game mode and map you are playing, as well as your loadout, and your own personal preferences. You can complement perks with your weapons and equipment to enhance your online play substantially.
    The perks list in Ghosts has been divided into 7 categories (speed, handling, stealth, etc.) and each category has 5 perks. Rather than being restricted to only 3 per class, like in Modern Warfare 3, you have 8 points to spend on them - each perk costs between 1 to 5 points and can be equipped from any category. If you opt-out and don't choose a primary weapon, secondary weapon and equipment, you have up to 12 points to spend on them.
    Each perk in Create-A-Soldier has its own unlock level and Squad Point cost, but only one of them needs to be fulfilled. If you reach the listed level, you unlock the perk and after that it can be equipped, but you can also unlock it earlier by spending Squad Points for immediate access.
    Like in Black Ops II, there are no Pro Perks in Ghosts multiplayer.
    Speed
    Ready Up (1 point)
    perk speed ready up 1Your weapon is ready faster after sprinting. Ready Up's quicker aiming after sprinting can reduce the number of deaths you suffer from sprinting into a combat engagement.
    Sleight of Hand (2 points)
    perk speed sleight of hand 3Cuts your weapons reload time in half. This perk is helpful to almost any weapon, but it's especially useful to guns with shallow magazines, slow reloading times, or weapons that burn a lot of ammunition quickly.
    Agility (2 points)
    perk speed agility 3Agility increases your movement speed. Exactly how much of a benefit you get from this perk depends on your equipped weapon. Handguns and SMGs move the fastest, followed by Shotguns, Assault Rifles, etc.
    In normal combat, it lets you quickly reach key conflict points on a map, travel through a flanking route more quickly, escape from a losing battle, or move faster to land a lethal knife kill.
    Agility is effective with Marathon and either an SMG or a Shotgun; this lets you close the distance to fully exploit your close-ranged weapons. Learning when Agility can give you a decisive positional advantage takes time - its effects aren't immediately obvious in a straight fight.
    Marathon (2 points)
    perk speed marathon 3Gives you unlimited sprint. Marathon is very important in any game mode that requires rapid mobility, which is almost all of them on offence. It's also useful for quickly cutting off chokepoints before the other team arrives or for reaching spots and contested overlooks.
    Stalker (3 points)
    perk speed stalker 3Allows you to move faster while aiming down the sight. Stalker basically gives you 100% walking speed while you ADS - this can give you the edge in mid-range firefights.
    Handling
    Strong-Arm (1 point)
    perk handling strong arm 3Allows you to throw equipment farther away; It also cooks your grenades faster. Enemy Frag Grenades can be safely thrown back due to Strong-Arm resetting the explosives timer.
    On The Go (2 points)
    perk handling on the go 3Allows you to reload while sprinting.
    Reflex (2 points)
    perk handling reflex 3Swap primary and secondary weapons faster - useful for players carrying a sidearm. Even weapons that are slow to bring up, like Shotguns, LMGs, and Sniper Rifles, are readier more quickly.
    You can also use equipment twice as fast - this basically means faster recovery from throwing grenades, and quicker equipment deployment, which leaves you vulnerable for a shorter duration than normal.
    Steady Aim (2 points)
    perk handling steady aim 3Increases hip-fire accuracy for all guns by reducing the normal spread factor by over 30%. This is a substantial improvement, generally bumping a gun one step up the accuracy scale.
    Steady Aim is very useful for the run-and-gun player, because ADSing takes time, and movement speed while ADS is reduced. Firing from the hip has neither of those disadvantages. Coupled with the fact that bullet impacts slow player movement and cause view recoil, the first player to score a hit in a CQB is often the victor. Steady Aim helps you to get that first hit and get hip-fire kills at a moderate distance with SMGs.
    Quickdraw (3 points)
    perk handling quickdraw 3Allows you to aim down the sight (ADS) of any weapon twice as fast. This reduced ADS time makes Handgun and SMG sighting lightning fast. Assault Rifle times become very quick, and LMG times become fast enough to use more safely in medium-range engagements.
    Cutting down ADS time can increase your chance of scoring a kill in a firefight where you spot an enemy in the open who can see you. You are all but guaranteed to line up the first shot more quickly than your opponent does.
    Stealth
    Takedown (1 point)
    perk stealth takedown 3Take out enemies silently without revealing their location. Normally downed players show a skull above their body that their teammates can see, but this perk disables that for enemies that you take out.
    Blind Eye (2 points)
    perk stealth blind eye 3Enemy air support and sentry killstreaks can't see or detect you - it also makes you immune to Oracle systems. Although air support killstreaks can't target you, you can still die from collateral damage if you get close to a teammate that doesn't have Blind Eye.
    Dead Silence (2 points)
    perk stealth dead silence 3Allows you to walk, sprint and jump almost silently. Most skilled players rely heavily on sound to warn them of enemy presence, whatever their radar might say. Dead Silence removes the warning that footsteps give.
    Incog (3 points)
    perk stealth incog 1Makes you resistant to enemy targeting systems like Recon, Thermal, Tracker Sight and Motion Sensor.
    Incog also prevents the red name and crosshair from appearing above you if an enemy targets you; this can cause temporary confusion to the enemy and could give you enough time to get the upper hand.
    Off The Grid (3 points)
    perk stealth off the grid 3Gives you immunity to enemy Sat Com killstreaks and radar pings by not showing you on the radar.
    It's strongly recommended pairing this with a silencer if you plan to engage enemies behind their back. Firing an unsilenced round with no friendly blips near you on the radar usually attracts enemies to your location.
    Awareness
    Recon (1 point)
    perk awareness recon 3Enemies that are damaged by explosives are tagged and can be seen through objectives for a short time.
    Scavenger (2 points)
    perk awareness scavenger 3Scavenger causes slain enemies to drop ammo packs that you can pick up. These blue packages replenish your primary and secondary weapons' ammunition.
    Scavenger's power increases the longer your average lifespan is. If you play a very run-and-gun build prone to dying quickly, you won't get much out of Scavenger. On the other hand, if you are a more cautious player, Scavenger can allow you to defend a fixed position almost indefinitely.
    This benefit is usually more pronounced on medium to large maps, where you have time to pick up supplies and get out of sight. Smaller maps, with their high rate of conflict and frequent close spawns, give you less of a chance to catch a breather and stock up.
    Amplify (2 points)
    perk awareness amplify 1Makes all enemy sounds louder. This is a ridiculously strong bonus. Used well, it can almost feel like cheating. You can clearly hear enemy movements a good distance away, sometimes even through walls.
    It's recommended that you use a headset with this. The one bundled with every Xbox 360, Xbox One and PlayStation 4 isn't the best, but they are definitely better than using the speakers on your TV. In the end, it's better to purchase high quality headphones; they'll give you an advantage.
    SitRep (2 points)
    perk awareness sitrep 3SitRep causes enemy equipment and explosives to show up as bright red and visible through walls at a short distance. SitRep is very useful on offence. It's also useful for covering objectives, as you can quickly spot unpleasant surprises that the enemy team may have set up nearby.
    Wiretap (3 points)
    perk awareness wiretap 3This perk allows your deployed Sat Com killstreak to hack into enemy Sat Coms. Hacked Sat Coms work normally for the enemy, but they also stack as your own Sat Coms.
    For example, if you have one Sat Com and the enemy has three, they stack as four Sat Coms for you - this gives you an "Advanced UAV".
    Resistance
    Resilience (1 point)
    perk resistance resilience 3Gives you near immunity to falling damage. You can still die from a lethal fall, but any nonlethal fall doesn't hurt you at all.
    In most situations, this simply is a nice bonus, but on some maps, you can get a lot of mileage out of this by sticking to high ground, safe in the knowledge that you can leap from a tall building without the fear of dying on impact.
    On some maps, this facilitates an easy getaway from combat, even if you take a hit or two while jumping.
    Painkiller (2 points)
    perk resistance painkiller 3Regenerates your health faster.
    Focus (2 points)
    perk resistance stopper 3This perk reduces weapon sway when aiming down the sight and also makes you flinch less when shot by the enemy. The flinch protection is useful with almost any weapon; if your view stays on target but your opponent's jerks wildly when you shoot him, you are more likely to come out standing.
    Tac Resist (2 points)
    perk resistance tac resist 3Tac Resist is a useful defensive perk that renders you nearly immune to Flash, Concussion or EMP grenades.
    It's great when you go for objectives where you expect grenades of all types to hammer you. But, because it depends on the enemy team using those grenades, you may or may not get a lot of mileage out of Tac Resist.
    Blast Shield (2 points)
    perk resistance blast shield 3Blast Shield slices all explosive damage you receive by over 50 %, meaning that anything but a direct explosive won't kill you. You can stand near C4, walk past Claymores, breeze by Semtex or Frag Grenades, and sprint through RPGs and Grenade Launcher fire.
    Blast Shield is most useful when you know you are going to take explosive damage, rather than simply because you don't like explosives. This perk doesn't save you from concentrated barrage of explosives by multiple players, but it does let you last longer, and it absolutely saves you from stray explosions.
    Equipment
    Extra Tactical (1 point)
    perk equipment extra tactical 3Gives you extra tactical equipment.
    Extra Lethal (2 points)
    perk equipment extra lethal 3Gives you extra lethal equipment.
    Fully Loaded (2 points)
    perk equipment fully loaded 3Gives you extra magazines for your weapons.
    Extra Attachment (3 points)
    perk equipment extra attachment 3Allows you to choose an extra attachment for both your primary and secondary weapon. This is a solid all-around perk, useful in many situations.
    Danger Close (4 points)
    perk equipment danger close 3Increases explosive damage. For example, Frag Grenades have enough explosive power to take out players at the edge of its blast radius.
    Elite
    Gambler (1 point)
    perk elite gambler 3Gives you a random perk, even one that you have already selected.
    perk elite gambler screenshot
    Hardline (2 points)
    perk elite hardline 3Reduces the amount of kills you require for any killstreak by one. It has a profound impact on the frequency of killstreaks you generate. It's less noticeable for very high-end killstreaks, but taking any of the six or below streaks can greatly increase frequency.
    Ping (2 points)
    perk elite ping 3After killing an enemy this perk activates a sonar ping that reveals other nearby enemies.
    Overkill (3 points)
    perk elite overkill 3Allows you to equip two primary weapons. Overkill is very useful for running two weapons of different ranges. With an Assault Rifle / Shotgun combo, you can clean up close quarters with the Shotgun, while engaging long-range targets with your AR.
    Deadeye (5 points)
    perk elite deadeye 3Consecutive kills increase the chance of your weapon to cause more damage to enemies.
    Experience: 2,136,432
  2. The Following 4 Users Said Fucking Hell Yeah ! to NIGHTMARE For This Fucking Post:
    AGC Ninja (November 3rd, 2013),K0NV1CTXx (November 3rd, 2013),Kujeaux (November 3rd, 2013),Sidebangx (November 8th, 2013)
    May 26th, 2025
    12:45 AM
    Oh believe me NIGHTMARE I've got that covered. If you want intel on the weapons let me know bro, I've been watching closely to the weapons. The ability to create 60 classes I'm gonna be having all 60 made lol ! Oh yea bro
    Sent from a classified location
    Experience: 36,430,795
  4. The Following 2 Users Said Fucking Hell Yeah ! to Randuken For This Fucking Post:
    AGC Ninja (November 3rd, 2013),NIGHTMARE (November 3rd, 2013)
    NIGHTMARE's Avatar
    Rep Points: 14083
    May 25th, 2025
    08:45 PM
    Stony Brook, NY
    haha yea trying to get an early start on my no sleep marathon
    LONEWOLF's Avatar
    Rep Points: 46573
    May 25th, 2025
    07:45 PM
    Orange Park, Florida
    Great find Nightmare.
    Experience: 12,230,936
    NIGHTMARE's Avatar
    Rep Points: 14083
    May 25th, 2025
    08:45 PM
    Stony Brook, NY
    Thanks some of these perks are cool I like how they made attachments and extra lethals part of the pwrk system now
    Sent from my SAMSUNG-SGH-I717 using Tapatalk
    HEADHUNTER1030's Avatar
    Rep Points: 45129
    May 25th, 2025
    07:45 PM
    Atl,GA
    Great find can't wait put these combos together
    Live life to fullest h
    Experience: 7,851,448
    May 26th, 2025
    12:45 AM
    Yea bro it's gonna take me sometime to assembly perk combos for each game type. That's not even the beginning. The different variances for those game types.
    Example: having domination offensive, defensive classes. Objective, support, slayer oh buddy lol brace yourselves guys we're gonna have long threads in the coming weeks.
  10. The Following User Says Fucking Hell Yeah ! to Randuken For This Fucking Post:
  11. #8
    Sidebangx's Avatar
    Rep Points: 49077
    May 25th, 2025
    04:45 PM
    Washington State
    Team no sleep either tomorrow or sunday! Got me all pumped for this!
    -I done wrestled with an alligator!
    -Done tussled with a whale!
    -I Handcuffed lightning!
    -And threw thunder in jail!
    -Ive murdured a rock!
    -Injured a stone!
    -Hostpitalized a brick!
    Im so Bad I make medicine sick. Im gon' Show you! How great I am.
    "Whatcha' gon' do, When the CAG Doggs come for you?"
    CAG Dogg Level: 43 [?]
    Experience: 3,220,537
    Next Level: 3,609,430
Members who have read this thread : 1
